Air Bag Module
I have (or had) a wrecked '94 GT and then bought a '95 six cylinder. I took everything from the '94 and put it into the '95. Yes every wire cluster, rear end, engine, trans, dashboard, ABS brakes and interior (black leather). I then went to use the air bag module but it was not the same. The one from the '95 has a part number F5ZF-14B215-BA. Do not have the one from the '94. The wiring connectors are different and have a different number of wires. The one clip on the '94 has 5 wires and the other clip has 10 wires while the '95 clips have 7 wires and 11 wires. The '94 has male clips while the '95 has female clips Everyone that I have talked to says the modules should be the same for '94 and '95 but this is clearly different. Has any one ran across this before? Can the '95 module be wired to accept the '94 wiring harness?
Lethaldosage423
Oct 19, 2015 12:12 AM
