ticking noise
ticking noise
ok i have a problem with a ticking noise from the engine of my 87 mustang, i thought it was my roller rockers but they are all adjusted correctly, but im pretty sure the rockers are making the noise, could one of my lifters be out? any help would be apreciated
RE: ticking noise
it makes the noise all the time and the ticking quickens with engine rpm, as for adjusting then i have adjustable rockers so when the intake was closing i adjusted the exhaust a turn and a quarter, and when the exhaust was opening i adjusted the intake a turn and a quarter.
RE: ticking noise
From flowtech inductions site:
4. Twist the intake push rod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the push rod, you are at "Zero Lash". Turn the adjusting nut down one half to three-quarters of a turn from that point for street applications. Use 1/8 to 1/4 turn for race applications. Lock the adjuster into position. The intake is now adjusted properly.
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at ?Zero Lash?. Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
