Now Bad News plz help
#23
RE: Good And Bad News
ORIGINAL: 88 rubber eater
lol, thats ok she is. but do you guys have any insight on what is causing my car to shake a little? Also should I change the oil again? thanks again
Just kidding. My car does the same thing. It feels like someone is standing outside, knocking against the car at random intervals. This is what I've done to try to correct the problem:
Cleaned (and eventually replaced) the IAC, and replaced gasket
Cleaned MAF electrodes
Changed spark plugs and wires
Changed cap and rotor
Changed PCV valve/cleaned screen element
Changed o2 sensors
Changed motor mounts
Adjusted TPS
Adjusted timing
Used seafoam
Changed a vacuum hose or two
Cleaned EGR valve, and replaced gasket
Performed cylinder balance test--passed
Ran codes--passed
Tested thermactor system--passed
As you can see, I've made an attempt or two to fix this problem. Nothing I have done has had any effect whatsoever on the rough idle. At this point, I don't worry too much about it--the car runs awesome. In terms of what I will try next:
Explore the idea of a manifold vacuum leak (when I get around to swapping out the stock manifold)
Replace the harmonic balancer
Beyond that, I have no idea. Hope this helps. Congrats on the car, and the pimp-evening.
#24
ORIGINAL: 5.0stanger
How do you know it is off?
ORIGINAL: Stevens91gt
as long as i dont have the "low oil" light
i figure its good
but usually my dipstick is off
i figure its good
#25
Thanks guys, that now makes my life a lot easier, but I think Im going to change my oil again in 1,000 miles. When I got the car it was pretty black and I thought about not buying it, but for 1100 and the car ran soooooo damn good I had to get it! Twisted, did you see any difference in performance or gas mileage when you used seafoam? I want to do that. OH!, my biggest question right now is about my fuel pump. When I turn my car off my fuel pump stays running and ends up killing my battery. My alternator is already dying (especially with u/d pullies) so this only makes the problem worse. So EVERY time i stop somewhere I need to unhook my battery, its such a pain in the @$$!!! I looked to see if there was a fuse controlling the pump but i didnt find one. Please help e out here guys. Thanks again
#26
#27
Well heres the predicament. Occassionally the pump will shut off by itself, but it normally just satays running. So ill unhook the battery when I go somewhere and when I come out and hook it back up b/c Im leaving the pump will stay off sometimes. Sometimes it turns back on, others it stays off. Im clueless guys
#29
its full when the oil reaches the arrow pointing to the hashed areas
if its over the arrow its over filled
i over filled mine a little bit too but i just ran it as is. she dosnt smoke and burned most of that excess oil off and its good now. i need an oil change soon and i checked it the other day was a little bit below but i also got a leak at the drain plug. damn washer broke in half.
personaly i wouldnt worry about it unless it was really over filled.
these cars are 5 liters therefor hold 5 quarts of oil. u can put more oil in them i know my chevy 305 was a 5.0L but liked 6 quarts of oil. she was a smoker tho and ate oil faster than gas [8D]
#30
The realay is under the driver seat? Like under the carpet? I just swapped out my drivers seat this weekend and didn't see anything but carpet, but I didnt look underneath it. Can you be more specific in the location please 5.0stanger? Again, you guys are awesome
