blackish smoke and rough idle'ing.
RE: blackish smoke and rough idle'ing.
The idle screw? You will have to re set TPS (throttle position sensor)voltage. It is that black thing that sits on top of the throttle body. It measues the position of the throttle to let the computer know how much gas to let in. If you have this out, you can run rich.
ORIGINAL: 5.0stanger
thats the TPS sensor right?? how would i re-set that?
could it be a MAF sensor also? my bud just told me that if i take unplug the MAF from the intake it might change something??
another thing. since i got the new computer, do i need to re-calabrate it at all?
[IMG]local://upfiles/30217/C0FA25E320A34AD3A9B153759ACD49BD.jpg[/IMG]
https://mustangforums.com/m_969165/tm.htm
That is your TPS. You shouldn't have to re calabrate your computer. I don't know about the MAF
What type of exhaust do you have on it? the black smoke could be caused by soot in the mufflers from not being run or if you are running glass packs it could be from the fiberglass in them burning up and going away causing it to sound as though it is missing and getting louder also.
I do agree i would check the tps and work on the fuel if it is a greyish blue that is caused by it running rich
the exaust i believe is stock, the kid who owned it before me cut the rear two cat's off. stupid.
the headers back need to be replaced (waiting for some shortie headers with offroad xpipe).
its weird because before i had that issue where it turned off on my while driving, i havent drove it, but the sound before was good. now it sounds like it has a bad cold or something.
