timing
Old Jun 14, 2006 | 02:25 PM
tl86gt's Avatar
tl86gt
Default timing
ive got a bone stock '86 mustang gt. im wanting to advance the timing to 14* but im not sure if that would be safe with 93 octane. i live in mid-low altitudes, so think it would be ok but i dont want to have to change the timing again to keep it from knocking. any info will be greatly appreciated
Old Jun 14, 2006 | 02:40 PM
Frebius's Avatar
Frebius
Default RE: timing
Here is a very good thread on advancing your timing.
https://mustangforums.com/m_1498746/mpage_2/key_/tm.htm
You should be just fine bumping it to 14*'s if you are using 93 Octane. As far as you only setting it once and that it. That is not exactly how setting the base timing works. Just because you bump your timing to 14*'s doesn't mean that it is the optimal setting for your car. you could be loosing HP because it is set to high or loosing HP because it's too low. To properly time your car you really need to goto a drag strip or to a Dyno and play with the settings. Hope this helps
Old Jun 14, 2006 | 04:28 PM
tl86gt's Avatar
tl86gt
Default RE: timing
ive seen a few people with 12* timing on a stock motor, so maybe thats the way to go. sucky thing is nearest drag strip is 120 miles and nearest dyno is at least 60......but my mechanic thats doing it has alot of experience with fox mustangs, so hell have a suggestion. thanks tho
Old Jun 14, 2006 | 04:31 PM
88BlueGT's Avatar
88BlueGT
Default RE: timing
Im going to try and run 12* on a 100% stock motor this weekend. From what I am understanding from other people I should be fine but I might need to run 89 octane instead of 87. No big deal though.
Old Jun 14, 2006 | 04:47 PM
P Zero's Avatar
P Zero
Default RE: timing
Hmm......my factory base timing is 13*. Go figure, must be the carb
-P.
Old Jun 14, 2006 | 04:51 PM
88BlueGT's Avatar
88BlueGT
Default RE: timing
Wierd.....
Old Jun 14, 2006 | 07:31 PM
94Cobrakid16's Avatar
94Cobrakid16
Default RE: timing
i put mine to 14 over a week ago, and the last 5 days or so, i swear my car feels less powerfull. i dont know if its all my head or what.
Old Jun 14, 2006 | 11:31 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: timing
w/ 93 octane 14* should be fine.
i sprayed on 93 and 14* last weekend and was all good.
w/ 87 stay at 12* no higher unless your power timing or dyno tuning
Old Jun 15, 2006 | 01:19 AM
03BottleFedGT's Avatar
03BottleFedGT
Default RE: timing
i have been running 15 on 93 octane for about 8 months and the car is just fine. and has better throttle response
Old Jun 15, 2006 | 01:23 AM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: timing
I had mine of 16 before with a bone stock and it didn't ping. After 14 I don't think you gain anything though when its stock
