Radiator Fan
RE: Radiator Fan
i run two fans...a pusher,and a puller....i use a radio shack relay.run one hot wire(which ever way you want the fan to turn) to relay then run source wire from relay with an inline fuse to a toggle switch/or key on wire(stay away from heater control wires.....
why don't you test it off your battery then you'll know if it's good or not?
RE: Radiator Fan
Ok, sorry about all this.
I just need to get all of this straight.
I need a fuse, and a relay. I take one of the wires, ground it to the frame and then run it to a fuse in the radio?
Then I take the next wire, ground it to the engine block and then put that in a relay with an on off switch?
RE: Radiator Fan
i would,but not to a radio positive fans have a major drain....i got lucky in my fuse box.had a open fuse that wasn't in use i think it was for if i was a vert for the top.....try to find a fuse holder that is 20 amps or higher.
RE: Radiator Fan
here I went directly off of this article:
http://www.fordmuscle.com/archives/2...cfan/index.php
The fan controller I purchased at Advanced for like $50. It comes with a temperture probe and a 30 amp relay. This is all you need unless your using a Taurus or Mark IV fan then you will need a 75 amp rated relay. If you need one of those let me know.
RE: Radiator Fan
ORIGINAL: grabbem88
I dont like running hot wires through the firewall if I dont have to.
