HESITATING engine please help!!!!!!!!!
Old Jun 17, 2006 | 09:13 PM
ckyguy68's Avatar
ckyguy68
Default RE: firing order please help!
another thing, did you check the TPS voltage?
Old Jun 17, 2006 | 09:43 PM
g2_5point0's Avatar
g2_5point0
not sure if your tfi module is old, but i suggest replacing it. mine was brittle and breaking into pieces. for 20 something bucks, its an easy fix and may remedy some problems
Old Jun 18, 2006 | 03:28 AM
number1_kid's Avatar
number1_kid
Hum.....
did not check the TPS voltage
and cold or hot it runs perfect idle
just starts to hesitate over 2500rpm till 5000rpm
sometime it runs perfec but like only 10 seconds
Old Jun 18, 2006 | 04:02 AM
5.0 MPG's Avatar
5.0 MPG
Jack up front and rear license plates, remove car, insert new 5.0, problem solved.
Old Jun 18, 2006 | 06:12 PM
number1_kid
top
Old Jun 18, 2006 | 06:27 PM
302RideOrDie's Avatar
302RideOrDie
Default RE: HESITATING engine please help!!!!!!!!!
Yeah mine kinda hesitate's sometimes, idk.. what it is, it'll hesitate then it will come in real strong and run fine, so idk i'm thinking i need a new fuel pump or my vaccum hose is acting up..
Old Jun 18, 2006 | 07:33 PM
number1_kid
new fuel pump and vacum
from gas tank to front and all wiring cap rotor all is new
Old Jun 18, 2006 | 08:49 PM
gr84u's Avatar
gr84u
Think I have the same thing, when I went to take it beyond 3,200 or so it feels like I drop the clutch in and it isn't catching, it is the engine because it kind of kicks down. I am pretty sures our is similar problem. Mine is also an 87.
Old Jun 18, 2006 | 09:09 PM
silver91gt's Avatar
silver91gt
ORIGINAL: g2_5point0
that is super cheap, the only place I could get one is from ford and that bugger was $180
now I just yank them from the junkyard.
Old Jun 18, 2006 | 10:13 PM
number1_kid
Mine dont feel like I am dropping the clutch
from 2500rpm to whatever
it just has a miss sound and is not pulling at its full potential
it never did this the first 2 days I had it.
dont know whats wrong now
Went to a friends house
same stang as me
we change EGR valve and his trottle body
still had the same problem
then we chanegd the coils
still same problem
