HESITATING engine please help!!!!!!!!!
yes there is, all fuel injected 5.0s had them,
there is a plug going to your distributor, the plug plugs into the grey rectangle thing on the distributor, that is your TFI (thick film ignition) also known as the ignition module.
Same I changed my sparks on Thursday, mine I guess doesn't feel like I am dropping the clutch, more like bogging. I never did check my cap and rotor... I'll look into it. More suggestion is always a help for to people with similar problems.
i really do think its a very simple problem, and its not worth selling your car over. when you installed your plugs, did you use a spark plug wrench? the rubber on the inside serves two puposes. 1. It holds the spark plug, and 2. It keeps the plug from cracking. a cracked plug will not fire. next step would be to get a fuel pressure gauge and check your f/p when the problem is occuring.
ORIGINAL: number1_kid
the piece of **** is going to a shop tomorw
they cant find it this week
selling
selling
