HESITATING engine please help!!!!!!!!!
Old Jun 20, 2006 | 10:25 PM
  #41
number1_kid's Avatar
number1_kid
Default RE: firing order please help!
Ya 5 speeds
Now my ****ing piece of **** is now back to the hesitatiing problem!
Potential for sale pretty soon!
Old Jun 20, 2006 | 11:00 PM
  #42
5.0stanger's Avatar
5.0stanger
Check your plug gap.....
Old Jun 20, 2006 | 11:03 PM
  #43
number1_kid
read the other posted
gaps where checked
all is new
gaps re checked
still hesitatin above 2500rpm
ALL IS NEW
Old Jun 20, 2006 | 11:08 PM
  #44
5.0stanger's Avatar
5.0stanger
You never said you checked the gap, just said plugs are new....What kind of plugs you running and what is your gap? Clutch adjusted right? What is your timming set at? Air charge temp sensor maybe...you run the codes?
Old Jun 20, 2006 | 11:10 PM
  #45
number1_kid
Gives me no codes on the computer
check engine dont light up
its gaps like ford told me I dont have the paper in front of me.
ALL MECANCICS say to run ford plugs. Motocraft thats what i put in
clutch is fine
nothing to do with that
its a hesitating sound like lack of power.
Old Jun 20, 2006 | 11:16 PM
  #46
5.0stanger's Avatar
5.0stanger
How old are you?? You kind of seem to have a bad additude considering I am trying to help from experience....be nice, we are tying to help
Old Jun 20, 2006 | 11:34 PM
  #47
ZachW04Stang's Avatar
ZachW04Stang
Have you checked your timing? Base timing should be at 10* BTDC. Also are your spark plugs gapped right .048-.052 is what the emission sticker says. If its anything different than that it would throw your timing off.
Old Jun 20, 2006 | 11:37 PM
  #48
5.0stanger's Avatar
5.0stanger
Here let me answer for him....
Can't you read
Timming is good
Plugs are right
LOL couldn't help myself Like we are bugging him
Old Jun 20, 2006 | 11:52 PM
  #49
onetrickpony's Avatar
onetrickpony
I had an 85 GT that had this same problem. It was a bare wire in the engine that would make it start to sputter at around 2500 to 3000 rpms, I cannot remember which one it was, it was like 10 years ago. It drove me nuts for a week and then a friend of mine came over and we found the wire, it was not totally bare but a little piece of the coating was gone. Hope this helps.
Old Jun 21, 2006 | 12:04 AM
  #50
red302's Avatar
red302
Default RE: HESITATING engine please help!!!!!!!!!
What is your timing set at? What is your fuel pressure at idle & wide open throttle? Check the vacuum at your fuel pressure regulator and see if it's leaking too. Does it backfire from the throttle body at WOT? I spent a month dealing with the same problem on my 93 GT and I started checking my entire ignition system, then moved on to my fuel system. Turned out to be a bad mass airflow sensor
