Studdering problem HELP
RE: Studdering problem HELP
ORIGINAL: 5.0stanger
I have a code reader...I got a few egr codes, cus it is all removed, no 111....Pulled a code 34, 81, 82, 84, 85...egr stuff
34 = EGR Valve Position/Pressure Feedback EGR Voltage Above Closed Limit. did you eliminate this properly?
[IMG]local://upfiles/37956/EAF174E668A24992905EB72D65200C2C.gif[/IMG]
yeah, vented gas cap...been that way for 3 years
As far as removing the egr properly, I tried setting the switch, but it may be in too far..what is the voltage supposed to be?? Maybe I can adjust that, but it runs good(before this studdering problem) It has been off for 6 months, no problems.
Ran codes again...got 34, 44, 94....what are the 44 and 94? Thermactor air system problem on the right side is 94(what is that?) Then 44 is just a problem with that system...is that a lean code or bad o2 or something??
Okay...I looked it up and found out it is the smog stuff...is that okay to have those codes? I don't know if I had them before...probably...I don't know
stangin1996gt
09-21-2015 11:01 AM
