front end grinding
Old Jun 20, 2006 | 11:48 PM
ben5.0's Avatar
ben5.0
Default front end grinding
when i turn my steering wheel the front end (suspension) seems to make like a grinding type of sqweek. i was wondering if there is a way to maybe lube it up, or maybe sumtype of bushing has gone bad? its really annoying on top of my bad throwout bearing. waht is this noise?
Old Jun 21, 2006 | 12:36 AM
detroit50's Avatar
detroit50
Default RE: front end grinding
Spray some silicone on ur bushings and fill ur tie rods and ball bearings with grease
Old Jun 21, 2006 | 12:40 AM
foxontheprowl's Avatar
foxontheprowl
+1 sounds like an excellent start
Old Jun 21, 2006 | 12:42 AM
Stiffclutch's Avatar
Stiffclutch
If it still does it you will possibly need a new set of wheel bearings. which are not that hard to replace.
Old Jun 21, 2006 | 12:43 AM
Boss_Hotrod's Avatar
Boss_Hotrod
Check to make sure your wheels are rubbing your control arms. Thats a big problem on foxes with bigger tires. Also if you have a jack then jack the car and move the tire from 9 to 3 o'clock. If there's excessive play you've got a bad inner tie rod. Then move it from 12 to 6 o'clock. If there's ecessive play there then you're ball joints are shot.
Old Jun 22, 2006 | 12:15 PM
ben5.0's Avatar
ben5.0
thanks guys, when i get home from work today, i shall try these suggestions
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
the5
Sep 19, 2015 06:13 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
