94 5.0 does the trick flow wedged heades bolt up to a lower intake manifold from a cobra
i am swaping my 5.0 with a 308 with trick flow wedged heades and putting a 94 cobra lower and upper intake manifold on the engine i hear that the ports dont line up right i need to know before i put the engine togther thanks
RE: 94 5.0 does the trick flow wedged heades bolt up to a lower and upper intake manifold of a cobra
if your asking if the lower intake will bolt up to the heads then that is a yes....just make sure you get the right gaskets...
Calizic
08-28-2015 01:46 PM
