Overhaul on a 1990 LX
RE: Overhaul on a 1990 LX
You'll also want to start planning your next move as far as a stronger tranny....
Yes, as a person thats went through 3 T-5s with only about 315rwhp...thats the truth. But if i were you i go with the G-force 450hp tranny. Its about the same price as a rebuilt T5 and its a good trnny up to about 450hp as its listed.
ORIGINAL: 88stangaruu
oh and another thing man, the MSD dizzy isnt really nessecary, save the money you spend on that and put it somewhere else. I would however spend that money on a MSD or Hi-6 ignition box since your going to be runing that Zex kit. As far as bigger fuel pump and innjectors, get some 24#'rs off of Ebay or out of the paper, and your probably going to need a new fuel pump at the least, just for saftey of that nitrous. Get a 255 Walbro or BBk pump. But the stock dizzy is perfectly fine for up to probably 500-550hp. If it makes you feel any better go get a rebuilt one they're about $90 or so at Advanced auto with a core charge. Just a thought.
Check jdsperformance.com for the fuel pump and some other things....they have great prices and Dave is a nice guy.
thanks gspfunk but will the bbk headers bolt up to the mac prochamber corectly and would i need to get bigger injectors or bigger fuel pump, and also do you think i would need any gauges
ORIGINAL: LX 90
1--thanks gspfunk but will the bbk headers bolt up to the mac prochamber corectly and 2--would i need to get bigger injectors or bigger fuel pump, and also do you think i would need any gauges
2--24 #'s should be plenty for a N/A motor, even w/ more mods than yours... Replacing the fuel pump would be insurance on your part b/c you never know when the stocker will take a dump on you. Gauges are up to you...the stock gauges are not very accurate, but they'll work if you know where the readings should be.....
OK i think i might have changed my mind alittle bit. I will deffinently do the whole exhaust. im going to do just the 4.10 gears and the zex ket for now. Im going to save and buy a cam heads upper and lowers and pistons all at once. that way i wont put too much strain on the stock heads and parts. how does that sound any sugestions i could gett the 24# ingectors now too
Just be sure you do all your research...surprises are not a good thing when you're planning stuff out.
I think you may be able to keep your 19's for now, but someone that is spraying may have a better idea about that......
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
YoungStangsMan
09-05-2015 07:01 PM
