torque boxes
torque boxes
how much power and how hard can you launch a factory mustang (drag radial or slicks) before you gotta start worrying about damaging torque boxes,
and whats the best mods to prevent it.
any stories or advice would be cool
RE: torque boxes
Just get some re-enforcment plates from Jegs, tehy're like $24.00 and you just weld them in to the torque boxes. Cheap insurance. Polyurethane bushings are hell on torque boxes. When you upgrade control arms, run a urethane bushing on the rear ends side of the control arm. Run a sperical buhsing on the torque box side, it helps keep the arm from binding more and messin somethin up.
RE: torque boxes
Its definetly worth it to do them now and now wait until something DOES go wrong... then you will be spending 5x's as much to fix them.
Check out www.wildridesracecars.com
They have good quality stuff there.
RE: torque boxes
does that just re-enforce the actual torque boxes or does it also support the floor board around it.
is there any chance of cracking or breaking the floor around them?
and is it the uppers or the lowers that damage the easiest
RE: torque boxes
I've broke my drivers side. I started to notice that when i would accelerate in town or on the highway it would pull to one side when i gave it gas. I finally crawled under and saw the box ripped in half and the controll arm hangin. Then i went to one of the local body shops and he welded in some angle iron and said it would be stronger than ever.
RE: torque boxes
Definitly weld up the seams and get the reinforcment plates, you might even want to reinforce the floor on the other side of the torque box. I had a '79 5.0, one day I was racin my buddies stang, I nailed second hard, and the *** end of the car shot over to the right I let off the gas the car *** shot back to the left, my buddy motioned to me that my back tire was hittin the front and the back of the wheel well. I literally ripped the whole damn torque box off of the car, lower control arm still attached to the torque box, I cracked the frame right above the rear axle too. Tried welding it up, but the first time I drove it after that it just ripped right off again. So I stripped the car and sent it off to get crushed. It wouldve cost something like $2500 to repair it, I was 17 at the time so I didnt have the cash to get it repaired. So its just better to get them done BEFORE you break em, even when theyre cracked they make tons of noise, sounds like creaking from the back end.
-P.
-P.
