HELP ON REMOVING A PANEL!!
I need to fix my driver side window so i can pass a inspection. I'm not trying to spend money to do it. I tried a long time ago and i was told i cant do it without air compressed tools? Is this true or not? I need to take the damn panel off and put the window back on track!
RE: HELP ON REMOVING A PANEL!!
If your talking about the door panel is just unscrews then pops off. Then you well need to move the track toward the front of the door (should be two bolts that are 7/16" (i think). Lossen then then put the window back on track and secure the bolts. Reattach panel and your good ot go.
ORIGINAL: stanglx2002
what can of insepction are you going for that you need to fix the winder?
ORIGINAL: Boss_Hotrod
Just take your panel off about a hundred times. Ive done that and I could take it off blind folded. By the way im only 17. Ive been working on cars and tractors for as long as I can remember.
