Installing headers?
Old May 6, 2004 | 12:40 AM
fantasyfords's Avatar
fantasyfords
Default Installing headers?
Can headers be installed with the engine sitting in the car? I have heard you have to jack the engine up. Can anyone help with this??
Old May 6, 2004 | 02:44 AM
callmecobra's Avatar
callmecobra
Default RE: Installing headers?
depends on the car, and also if its long tubes or shorties
Old May 6, 2004 | 05:05 AM
USAMuscle's Avatar
USAMuscle
I'm assuming you mean long-tubes, because shorties can be swapped in in no time at all, without having to jack the engine up. I think it's easier to install headers with the engine jacked up because it gives you more room to maneuver since you'll need to go in from underneath the car. You may have to remove the starter and whatever else gets in the way...
Old May 6, 2004 | 08:04 AM
fantasyfords
No I auctually meant short tubes. Also what is a good brand of headers to buy? Equal or unequal lenght?
Old May 6, 2004 | 12:13 PM
roundman's Avatar
roundman
I would recommend equal length headers although they are a bit more difficult to install. I have a set of MAC equal length shorties that I installed in 94 and they are still working fine and in good shape too. I had a little trouble on the passenger side getting the one bolt in at the #3 cylinder due to the sharp bend in the header tube but you can cut a few threads off the bolt and it will go on in. On the drivers side, I had to make a small dent in one tube on the bottom side because it was touching the steering shaft just a little bit when the engine was idling but it moved off the shaft when you drive as the motor torque pulls the engine up off the shaft just enough to clear it under normal driving conditions.
Old May 6, 2004 | 12:30 PM
Obsol3te's Avatar
Obsol3te
Cmon Go Long Tubes! theyre more fun to put in.
You gotta try it WITH the engine in the bay tho
Old May 6, 2004 | 12:32 PM
roundman's Avatar
roundman
don't listen to OB, he put in long tubes and they kicked his butt for three days before he got them installed! go with the shorties!
Old May 6, 2004 | 06:09 PM
D1g1tal V3n0m's Avatar
D1g1tal V3n0m
I ♥ Acer
Get long tubes. Leave you alot of room for power gains in the future also.
Shorties are better then nothing but not that great.
fantasyfords
Three days??? Wow thats dedication. I woulda given up, sold em and bought shorties. See the thing is I have a o/r x pipe and if im correct longtubes wont work with it. So I just want something that will bolt right on. Hey roundman, you have a homeade ram air setup dont you? How did you do it and what did you use? Thanks again guys.
Old May 6, 2004 | 09:24 PM
MelloYello's Avatar
MelloYello
I put on BBK equal lenghts on my 5.0 wasn't too bad at all took about 3 hours.... I was able to put the headerin place through the top on passenger side then in place through the bottom of the car for drivers side.....
Have never worked with long tubes, so wouldnt know about those....
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
