Ticking under the hood...any ideas on a source?
#83
RE: Ticking under the hood...any ideas on a source?
They also took oil pressure readings...my pressure is 37 psi @ idle...they gave me two other numbers but they were all normal. My guage must just be screwing with me. (They told me it needs a new sending unit)
#85
Your oil pressure is on L at idle? I would take a oil pressure reading from an actual gauge, sounds like internal engine probs. Remember the cam drives the dist. and the dist drives the oil pump. Check oil pressure, dist shaft gear/shaft play, and oil driveshaft. DEFINATALLY remove belt first and run to rule out acc drive. While the belt is off check water pump shaft play and fan to shroud clearance... good luck
#86
ORIGINAL: will
read through the thread
#87
From my post back on July 2, glad you got it figured out
are sure its coming form the engine and not an accessory?
I was sure I had a main crank bearing going out, took the belt off so I could just hear
the engine better and sound went away.
Ended up being the smog pump. Check engine with belt off just to make sure. Takes about 5 secs to take belt on and off.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
