Polishing?
Old Jul 3, 2006 | 03:07 PM
titanium92's Avatar
titanium92
Default Polishing?
Anybody here know how to polish aluminum. Any tip or tricks or even websites will be helpfull thanks.
Old Jul 3, 2006 | 03:12 PM
Bad Karma's Avatar
Bad Karma
Default RE: Polishing?
Sand down the surface with some 600 grit sandpaper (lower # is it's a rougher surface) and then take some Mothers Aluminum polish and an old TShirt.
That's the best and only way I've ever done it.
Great luck to you,
Ivan
Old Jul 3, 2006 | 03:15 PM
sdmaker's Avatar
sdmaker
+1 on the mothers, good stuff.
Old Jul 3, 2006 | 03:17 PM
myshifter's Avatar
myshifter
I ♥ Acer
I would personally never use sandpaper on a porous and delicate metal such as aluminum, use a buffing wheel and your compund of choice to dress the wheel, the first compund you will use cuts the alminum, then switch to a rouge and polish. A finish like this? Check with http://www.caswellplating.com/ for all your needs
Bad Karma's Avatar
Bad Karma
They also make a newer Billet polish.
That's the Shizzle to use AFTER you got that thing looking nice. Apply it and it makes it cleaner.
-Ivan
Old Jul 3, 2006 | 03:35 PM
titanium92's Avatar
titanium92
Thanks for the responses, I will try it out.
Old Jul 3, 2006 | 03:52 PM
Bad Karma's Avatar
Bad Karma
ORIGINAL: myshifter
I'll give you credit on that one....and I agree. If it's Joe Backyard doing it though, then sandpaper is the only way to get it down to a smooth starting point prior to polishing.
Wouldn't you say?
Most people don't know alot about "buffing" or "compounds" so they resort to what they have or can readily get.
If they were looking for professional results then sure, you got the right answer there.
-Ivan
Old Jul 3, 2006 | 03:56 PM
myshifter's Avatar
myshifter
I ♥ Acer
heres the cheapest way you can do it, and I mean cheap. Got a bench grinder? If not well then **** how do ya work on anything. Ok so you do have one, go to menards, ace hardware, home depot, grab a 6 or 8 inch buffing wheel, 4 bucks MAX, then skip over and buy the 5 pack of polishing compounds (at menards), 9.99 and you can polish and it will turn out with a mirror finish that you could brush your teeth in. Never use 2 different compunds on the same buffing wheel.
Old Jul 3, 2006 | 04:00 PM
Bad Karma's Avatar
Bad Karma
ORIGINAL: myshifter
"5 pack of polishing compunds"
We dont' have Menards out West. Could you tell me a little more about what comes in the "5 pack" that I should look for when I would do to HD?? I'm assuming that there are different compounds in them right??
Thanks for clearing it up for us..
-Ivan
Old Jul 3, 2006 | 04:04 PM
myshifter's Avatar
myshifter
I ♥ Acer
ya it will come with different compunds for polishing fine metals, hard metals, brass and so forth. Home depot sells them individually. I dress one half of the wheel with the compund, you then cut the metal with that side, then use the other dry side for polishing it, take cotton cloth and wipe any excess off, will come out like a mirror
