12 sec 302?
Old 07-03-2006, 07:31 PM
incognito207
incognito207's Avatar
Default 12 sec 302?
im not a real big car buff but i know i want to build my '89 notch into the 12's so to whomp all these ricers i got around my area. What i need to know is what type of cam, intake, carb to put on my 302, and what rear end to have. Any suggestions?
incognito207 is offline
Old 07-03-2006, 07:33 PM
myshifter
I ♥ Acer
myshifter's Avatar
Default RE: 12 sec 302?
gt40 heads, b303 cam, edelbrock performer rpm and 650 holley with a 4.10 gear and with a driver will go 12's easy, did it 12 years ago in a hatch
myshifter is offline
Old 07-03-2006, 07:34 PM
white93 GT
white93 GT's Avatar
stock block, stock heads, 42lb injectors, new intake
and a 76 trim intercooled turbo.
there you go. 11's
white93 GT is offline
Old 07-03-2006, 07:35 PM
P Zero
P Zero's Avatar
Youll need a set of heads too. SOme C-9 or D0 casting 351 heads (1969/1970) would do nicely. Or if you can afford it some TFS twisted wedge or AFR 185's, if you go the aftermarket cylinder head route I'd reccommend am edelbrock Victor Jr. intake a 540/550 lift cam with 280/290 duration, and a 750 double pumper. Depending on how much you know about carbs Edelbrock makes some nice ones that are easy to work with. That should do ya.
-P.
P Zero is offline
Old 07-03-2006, 08:53 PM
Hung Like a Stang
Hung Like a Stang's Avatar
you could always use juice too, that'd get you there pretty quick
Hung Like a Stang is offline
Old 07-03-2006, 09:31 PM
r.barn
r.barn's Avatar
pretty much just about any alumimun head and upgraded cam combo
you throw on there would get you really close.
r.barn is offline
Old 07-03-2006, 11:25 PM
nitrous_bob
nitrous_bob's Avatar
ORIGINAL: P Zero
-P.
yeah those are great heads, but designed to run on leaded fuel. instead of DOOE's try some iron gt40's.....and port them a bit.....the DOOE's were the blueprint for the gt40's anyways. by the time you do some hardened valve seats, and other port work, you coulda done a set of iron 40's , open up the exhaust, and dump the bump. clean up the intakes and you'll run
my buddy went 11.80's on 40's like that....40 intake box stock, stock block, 4.10's and 125 shot on et drags.
nitrous_bob is offline
Old 07-04-2006, 01:10 AM
Synyster Racing
Synyster Racing's Avatar
Saturday night at the midnight drags, I drove my friends car. I went 14.54 on motor, and 12.90 on a 125 shot. Only thing done to the car is exhaust, gears, and nitrous... 12's are simple, go for it!!! Synyster
Synyster Racing is offline
Old 07-04-2006, 01:14 AM
FordMustangXBA
FordMustangXBA's Avatar
My car hits 12s with good, sticky tires. But I'm EFI, as you can see. It's also quite an investment. Just waiting for a S/C basically.
Then again, my car doesn't hit **** with a blown transmission.
FordMustangXBA is offline
Old 07-04-2006, 01:18 AM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
n2o
FiveLiterRiceEater is offline
Quick Reply: 12 sec 302?
