Which radiator
OK guys my radiator has a leak at the inlet hose (where the pipe connects to the end tank)
my choices are the following
ford Racing aluminum with plastic end tanks
http://store.summitracing.com/partde...0&autoview=sku
or the Summit racing aluminum radiator
which do u guys think I should go with..
I have a manual trans so the trans cooler fittings dont do anything for me however the ford racing is a upgrade oem fit (but with plastic end tanks) and the summit is a cheeper one prolly cool well also but wont be oem fit
otherwise I can buy your run of the mill parts store radiator OEM fit for prolly 100.00-125.00 tops..
I do plan to run a supercharger int he future so I have to keep that into consideration to I need a good radiator to be the one I will always run
Dave
Dave
Jegs has a whole kit for $599, aluminum radiator, FRPP hoses & water neck, thermostat, electric fan with thermostat switch, and a hi-flo water pump... I bought it, but havent put it on yet... supposed to be good.
-- ojm
-- ojm
ORIGINAL: OJMiles
-- ojm
-- ojm
do u have the part number or link?
Dave
