Could it be that the stock alternator isnt strong enough with my underdrive pullies an 1200 watt audio system? If so would a 100 amp alt. do the trick?
I dont think i have a capaciter an i did just get volts checked an they said it was fine so im thinkin mayb i jus need a stronger alt.? I just dont know how strong i should get. I was thinking the 3g but id rather get the 100 amp if it will b fine.
well do you know what the volts were at??? basicly waht a capaciter will do is store any excess power that your system is gunna draw when it hits, that way its takes less strain off the rest of your electrical system.
if it turn out that your volts are ok you prolly need a stronger amp, your alternator pully is slowing this one down so its not charging as much
