header gasket help please!
Does anyone have experience with copper header gaskets? Are they better than aluminum? Do they seal correctly or are there problems all the time? Would I be better off with aluminum or copper, or just a felpro header gasket? I DON'T want to take the headers off again to repair a leak or blown gasket so I'd rather just do it right the first time and spend the extra bucks.
I actually buy the factory replacement ones and bust out my die-grinder and enlarge the openings. You can use a dremel if you dont have a die grinder. I have no problems with the factory ones.
-P.
-P.
which set guys? here are the ones I'm looking at http://store.summitracing.com/egnsea...=KeywordSearch
I need to order right now so they can ship today. I need to do the stat ASAP so I'm gonna order it all at once.
N/m... if you have the 1 5/8" unequal shorties from BBK (as you mentioned in your other thread), then these gaskets should do the trick:
http://store.summitracing.com/partde...5&autoview=sku
Might wanna double check though. I'm only human, haha.
I think those are for different heads. I have stock heads and the bolt pattern looks different. I just got the felpro gaskets made for the stock heads. hopefully they'll be good, the guy @ summit suggested some $48 stage 8 bolts and the fpp1415 felpro gaskets.
Cost like $65 for everything.
Plus I still need to buy a stat tonight ugh
junior04
Sep 28, 2015 10:53 AM
