T-56 in a 5.0...
T-56 in a 5.0...
Anyone here have a T-56 in there 5.0? If you do, did you encounter any problems puting it in your stang? My mustang was an AOD and I just pulled out the AOD to put in a t-56. but when it came time to adjust the cable with the firewall adjuster and cable adjuster...I found that the fork seems to be sitting too forward and hits the bellhousing not letting the clutch disengage...i was told that the pivot stud is to small...and i should get a longer one...has anyone else experience this...now my car is just sitting there.
RE: T-56 in a 5.0...
take a grinder to the clutch fork and thin it out right around were it is sticking you are going to love the
t-56 best mony i spent so far
[IMG]local://upfiles/37675/F33D4E917D2249138DB736A9F2A6219C.jpg[/IMG]
The front part of the fork hits the bellhousing...as the fork moves forward to disengage the clutch the face hits the bellhousing...i cant really thin out the face of the fork...yea man i cant wait to have it running...but just this little detail is holding me back..
the only thing i had to do with mine is thin the fork out what tranny did it come from, what year is your car and did you buy a crossmember or make one you can see my one of a kind in the picture
My car is a 1990 and the fork is from a 5.0 with a t-5 I checked the part number at the dealer and they told me it was the right one. ( i got the fork at a junkyard for mustangs only)i bought the crossmember...
