mean detination
mean detination
i put together my motor about 9 months ago b4 i went to school and i finally got to putting it in my car, its got h/c/i headers and some other crap, it will idle at 14 degreese of base timing but with any throttle it will pop and detanate and i cant get any rpm out of it and i have no idea what else it could be cuz i double checked everything almost, please let me know if you have any ideas what it could be cuz i want to get this peace running good... thanks
RE: mean detination
whats ya totle timing set at..not ur idle timing your totle timing..most folks dont knowwhat totle timing is and its importnat.and id start by backing ya initial timing a few degrees and try that
RE: mean detination
i put it down to 10 degrese base and i cant get enough rpm out of the motor to get total timing like i said b4, im running a z 303 cam, afr 185 heads, trick flow track heat intake, 70mm t/b - egr, 76mm maf, 30 lbs injectors, and a cheeter box for a/f ratio, 306 bottom end, long tubes and h pipe, and msd coil, 6al box and distrubitor. on 103 octane, and a lot of sauce to go threw the motor as soon as i get it running right
RE: mean detination
how are you checking base vs. total timing? you shouldnt need to rev up engine to get total timing
just take that spout connector on and off.
ORIGINAL: rwdguy86
RE: mean detination
someone ran my plug wires one time for a non-HO firing pattern
made car miss and pop and run like a 3 legged dog. only thing i can think.
Good luck
Good luck
ORIGINAL: rwdguy86
excuse me that was a mistype i have the spout out with for base timing at 14* with 103 octane
