110 octane leaded race gas
I am curious what u guys think..
I was wanting to dump maybe 3-4 gallons of 110 leaded race gas in my tank (I currenlty have roughly 1/4 tank..
again my stats are:
87 5.0 5spd
summit H pipes and summit duel exhaust with imco mufflers (no converters)
K&N drop in filter
ford racing 9mm wires
summit 40k volt coil
ngk G-power plugs
still running both oxygen sensors
just curious what u guys think.. should I run a can of NOS octane booster only or would it be ok for me to put 3-4 gallon of 110 race gas in my tank..
what will be the pros and cons of doing so?
I heard if I have no cats (which I dont) that I will be ok, but I have also heard that if u have o2's u can burn them out also
Dave
again my stats are:
87 5.0 5spd
K&N drop in filter
ngk G-power plugs
Dave
RE: 110 octane leaded race gas
well when i said designed, i meant all factory settings.
people have bumped up their timing without needing higher octane but if u advanced ur timing and u hear pinging, u need to run higher octane.
ORIGINAL: mustang93
if the car is made to run on 87 and you bump up the timing to 14* shoud you run 93 octane even though the car is made to run on 87? (sorry to hijack the thread)
