What's this and why is it loose?
The next clamp down on this hose line is very loose, and I'm having a hard time getting it mated to clamp it down, like the hose is .25 inches too short to connect properly. It's barely connected at all.
[IMG]local://upfiles/39585/E2F650F618654F5E995CA6A9BBC90482.jpg[/IMG]
RE: What's this and why is it loose?
that hose goes from your heads to your smog pump. it should be a vacuum in there since the smog pump sucks smog out. but dont let it get loose cause if u loose air through there, you loose compression and power
ORIGINAL: Bumsdeclaf
yeah that cant be true because thats the air check valve
mine snapped in half and my car runs fine
personaly i wouldnt mess with it
its very fragile and if it cracks even slightly it will break in half
try to get a new clamp , start it (mate it ) up close to the top and then slide it down the hose to its posistion... then tighten it up.. you may need a friend to gently press the hose and fitting towards eachother to tighten them.... good luck
