Problem
Old Jul 12, 2006 | 12:52 AM
titanium92's Avatar
titanium92
Default Problem
The problem- I"m having is poor idle, oil pressure seems to drop, and when I accelerate feels like i'm towing a big boat seems gutless. What could cause this.....is it possible MAF sensor...cause this? A couple of days ago I check codes and reading low voltage to MAF sensor.
I cleaned out with electrical contact spray, cleaned the iac with TB cleaner. I also adjusted the timing about 4 days ago as well. I think it's about 14 degrees, and i'm running 92 octane gas. Or could it be the timing that I adjusted or perhaps spark plug. Seems like it's surging when idling. Any feedback to help me narrow down this problem would be greatly appreciated.
Thanks.
Old Jul 12, 2006 | 01:10 AM
titanium92's Avatar
titanium92
Default RE: Problem
Anyone????
Old Jul 12, 2006 | 01:15 AM
Bumsdeclaf's Avatar
Bumsdeclaf
Default RE: Problem
ive seen that happen to a Passat once. it was sludge build up. its cause of humidity. hope thats not your case. i mean it was a passat, but it had the same symptoms
Old Jul 12, 2006 | 01:23 AM
titanium92's Avatar
titanium92
Default RE: Problem
Well not sure if it's that, or maybe because of my synthetic oil....I didn't know when I bought car it had synthetic and I changed oil to conventional and after few years using that I put in synthetic oil this year. I just think with the timing thing I did cleaning MAF and IAC...seems kinda wierd now that all this is happening.
Old Jul 12, 2006 | 01:43 AM
TENGRAM's Avatar
TENGRAM
Default RE: Problem
so...did you solve the MAF code? have you reset codes and checked to see if that one came back?
Old Jul 12, 2006 | 01:44 AM
titanium92's Avatar
titanium92
Default RE: Problem
No i didn't...that is why I asked could that cause all the problems I'm having...poor idle terrible acceleration etc.
Old Jul 12, 2006 | 01:51 AM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
Default RE: Problem
yup
Old Jul 12, 2006 | 02:14 AM
titanium92's Avatar
titanium92
Default RE: Problem
So the MAF sensor can cause all the problems I'm having????? If that's the case I will just buy new one.
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
