Installing 1970 351w heads onto a '91 302 HO
Old 07-12-2006, 12:09 PM
creeper
creeper's Avatar
Default Installing 1970 351w heads onto a '91 302 HO
I am needing to know what mods, if any, need to be done for me to install a set of '70 351w heads onto my '91 302 HO. The heads are 60 cc, with the large valves. As far as I see all I need to do is install the heads, 351 head bolts, 351 intake, and possible push rods. Is there anything that I have missed. And yes for those that may ask, I am getting rid of the fuel injection and going carbureted (cheaper to go fast carbureted than fuel injected). I am going to experiment from 600 to 750 and see which gives best performance.
creeper is offline
Old 07-12-2006, 12:16 PM
myshifter
I ♥ Acer
myshifter's Avatar
Default RE: Installing 1970 351w heads onto a '91 302 HO
head bolt inserts since 351's use a 1/2 inch head bolt and the 302's use a 7/16ths. 650 carb is plenty
myshifter is offline
Old 07-12-2006, 12:29 PM
aode08
aode08's Avatar
thats my setup lol
1.anyhow head inserts, the holes in the 351w heads bigger than a 302.
2. 351 heads miss the polution ports in rear, i loved that, id didnt like the tube on there anyhow.
3. Get thin racing ROL headgaskets for more compression, and or the heads shaved .10, i did both, very cheap !
4. USE HARDENED pushrods STOCK 302 lenghth etc. OH and yeah top it off with some 1.7 roller rockers or just use stock 1.6.
I run 13.4 in the quarter and AOD tranny, all day long and am very pleased with those heads.
you can run fuel injection just fine, its a direct bolt on.
aode08 is offline
Old 07-12-2006, 01:31 PM
aode08
aode08's Avatar
[IMG]local://upfiles/23896/00178E595ECE44799CD070B5DC1E7215.jpg[/IMG]
[IMG]local://upfiles/23896/CCB9CD13DDD44210A86CC2AD3EA863D0.jpg[/IMG]
[IMG]local://upfiles/23896/BC78AAF2CA9340A3A13D59E3BB32D3E6.jpg[/IMG] see that bolt, there is a circular piece in the hole that reduces its size, just pushes in like a button, very easy! Also 1.6 ratio roller rockers and hardened stock pushrods.
[IMG]local://upfiles/23896/6B848E3EB45B460BB86396F1AF73A5EF.jpg[/IMG] felpro gasket and race ported and polished, huge intakes
[IMG]local://upfiles/23896/6FEFE6CC9E384EC8B44A9B88E8872C81.jpg[/IMG]
aode08 is offline
Old 07-12-2006, 01:37 PM
myshifter
I ♥ Acer
myshifter's Avatar
the real downside to those heads, is if you run a spring with 175+ on the seat, you run the risk of pulling the pressed in rocker stud out.
Old 07-12-2006, 01:50 PM
aode08
aode08's Avatar
175?
shot of nitrous?
aode08 is offline
Old 07-12-2006, 01:52 PM
5IVE.OH
5IVE.OH's Avatar
Spring pressure. Not NAWS.
5IVE.OH is offline
Old 07-12-2006, 01:54 PM
myshifter
I ♥ Acer
myshifter's Avatar
ORIGINAL: aode06
175?
shot of nitrous?
no spring pressure, if you run a valve spring that has 175lbs+ of pressure closed on those stock 351 heads you can run the risk of pulling out the pressed in rocker studs. Those heads when used with a serious cam that needs a good amount of spring pressure to control the valves really need screw in studs, or at a minimum, pin the pressed in studs
Old 07-12-2006, 02:02 PM
aode08
aode08's Avatar
i never knew stock ones came like that, my studs are screw in studs, rated at a very high tensile strength. I love machine shops[8D]
aode08 is offline
Old 07-12-2006, 02:16 PM
myshifter
I ♥ Acer
myshifter's Avatar
ORIGINAL: aode06
ya someone put screw in studs in
Quick Reply: Installing 1970 351w heads onto a '91 302 HO
