timing
Old May 14, 2004 | 11:37 PM
bobby's Avatar
bobby
Default timing
hi i was just wondering what i should set the timing at on my 93 5.0, also the #1 cylinder is the 1st one on the left lookin from the front of the motor. thnaks mods are listed below if it matters , thanks a lot.
Old May 15, 2004 | 12:07 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: timing
yea, that's the #1 cylinder then it goes back and starts on the left with 5. If it's set at 10 now, which is stock put it up a couple degrees and see how it runs then if it's running well put it up another one or two till you get to around 14. The foxes seem to like it right around there. Make sure you disconnect the spout connector (pull the little black plug out that comes out of the ignition module on the distributor) before you do it.
Old May 15, 2004 | 12:25 AM
nhdungeonracer's Avatar
nhdungeonracer
Default RE: timing
I think Vert meant #5 starts in the front on the right That is if you're standing in front of the car, looking back towards the motor.
It can get confusing when some people say left, which is correct when sitting in the driver's seat.
Have I confused you anymore?
Old May 15, 2004 | 01:04 AM
VertStangGT86
Default RE: timing
LOL, yea yea, see I was probably mixing up in my head the looking at the engine and the mechanic's left and right. So yea, if you're looking at the engine from the front it goes 1-4 on the left side and 5-8 on the right.
Old May 16, 2004 | 12:51 PM
bobby's Avatar
bobby
Default RE: timing
ok thanks a lot for the replies now i just need to clean the rust off of my harmonic balancer so i can c the timing marks, LOL! will sand paper work ok, thanks again guys!!
Old May 16, 2004 | 12:54 PM
EmptyEvergreen's Avatar
EmptyEvergreen
Default RE: timing
may i suggest a wire brush those things work maricles
nhdungeonracer
Default RE: timing
Use a chalk to highlight the mark you want. It shows up better when you shine the timing light down on it.
Old May 16, 2004 | 01:19 PM
Mustang88LXKid's Avatar
Mustang88LXKid
Default RE: timing
ORIGINAL: EmptyEvergreen
o yah I hear ya man. those are so much help.
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
StalkerGT
Sep 25, 2015 02:41 PM
Sep 8, 2015 11:50 AM
