Need Help!
Need Help!
I'm lost on this... The problem is when i turn my headlights on, the dash lights wont come on and neither will my back lights or my parking lights... I know there is a fuse that controls the dash lights which i have replaced a million times cus he keeps blowing out. I can get everything to work if i wiggle the headlight switch around and get it to stay on in a certain spot where everything works fine... for now until the fuse blows out again. I thought the problem might be my headlight switch, but i put a new one in and it didnt fix it and i couldnt wiggle the new one in the certain spot that made everything work so i had to put the old one back in... I just dont know what to do now to figure this out. I dont want it to stop working all together, then i cant drive at night at all and replacing fuses every couple weeks is annoying... Please help!
RE: Need Help!
yea i hate electronics too... I thought maybe there would be someone on here that knows about electrical problems, otherwise im lost. a wiring diagram would help me trace the wires to see if i can find something... does anyone know where i can get one
RE: Need Help!
the dimmer switch works, it dims the lights and turns the interior light on like usual... i cant find anything else on the same fuse as the dash lights... everything else works fine. im lost
RE: Need Help!
Write down everything that works on that circuit, check your cig. lighter also. Remove the fuse, find the output side of the fuse holder(the side with no power) attach an ohm meter lead to the non powered side and the other lead to ground. Record value then start unplugging everything on that circuit 1 at a time while checking continuity to ground. When the continuity goes to open or inf you found the the prob. If you still have continuity to ground then you have a short to ground on the actual circuit. Pinched wire or green S*it formed by broken insulation... HAVE FUN
