bbk products/ adjuster
can some one tell me how the fire wall adjuster works for the clutch cable. I am thinking about getting this from bbk but is it a good one? is it easy to install? i want to get the quadrent and adjuster but i dont know if i am going to have to take apart the steering counsel to do it. Help?!
RE: bbk products/ adjuster
I went w/ the Steeda kit. There is a sticky about the install in the Tech section. The firewall adjuster basically screws in to the firewall where your stock cable is now. the new cable will fit thru the middle of it once you remove the rubber bushing and you can unscrew it to tighten up the slack in the cable.
