Next mods
Old Jul 14, 2006 | 11:59 PM
bouchermb's Avatar
bouchermb
Default Next mods
What would you do besides cam/heads with this set up?
5 psi Vortech SC Trim SC, TF Street upper/lower intake, 190 lph fuel pump, 73 MM MAF, 70 MM TB, pulleys, 30 lb. injectors, strut tower brace, subframe connectors, flowmasters, Bassani x-pipe, 355 gears, short throw shifter, BBK 1 5/8 equal length inch headers, ADCO anti roll sway bar, MSD TFI blaster coil, AFPR, boost/fuel pressure gauges, mass air conversion.
I'm wide open, so let's hear it.
Old Jul 15, 2006 | 12:48 AM
Stevens91gt's Avatar
Stevens91gt
Default RE: Next mods
curb feelers[8D]
nahh i have no idea[&:]
Old Jul 15, 2006 | 01:18 AM
r.barn's Avatar
r.barn
10 psi and power pipe upgrade for the voretch
TW heads with TFS stage 1 cam, upgraded valve springs.
255 pump and 42# injectors.
Old Jul 15, 2006 | 01:20 AM
duslep's Avatar
duslep
what size is your engine?
Old Jul 15, 2006 | 04:18 PM
bouchermb's Avatar
bouchermb
302. I was thinking about an Anderson power pipe. How hard is that to install? Stock bottom end.
Is 10 psi going to be O.K. or will I eventually blow the engine?
Good recommendations and appreciate the input.
Old Jul 15, 2006 | 04:20 PM
bouchermb's Avatar
bouchermb
BTW- What happened to our boy from last night?
Did he go off again sulking?
Old Jul 15, 2006 | 05:24 PM
brutal_gt's Avatar
brutal_gt
lightweight flywheel, aluminum d/s ugrade to a tko or t-56 tranny...
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
