Timing Gear Drive
Timing Gear Drive
Would it be worth it to buy a timing gear set instead of the traditional chain or double chain? I've seen a couple but they say you need to machine something....doesn't say what you need to machine though.
Also, would an electric fan from NAPA rated for a big block Ford work on my 85?
yeah i'm full of questions for my mustang.
More to come, thanks guys.
RE: Timing Gear Drive
there not realy worth it you will have to grind off the the the lip on the timing cover for it to fit and thay are veary noisy cause the idler gears in the middle rub the timing cover and it make a nasty screetching sound dont do it take it from me i had a set in my 87 4 about 200 miles !
ORIGINAL: 5.0stanger
I heard on the newer fuel injectied mustangs (86 and up) you can't use a gear drive cus of the knock sensor. Is that true?
