10 inch to 10.5 inch clutch conversion
ok i know that you can change some stuff around to get a 10.5 clutch in my car instead of having the little 10 inch that came with it...i got an 84 gt. anyway what do i need to do this?
RE: 10 inch to 10.5 inch clutch conversion
this is what maximum motorsports says to do for the converson
We recommend against reinstalling the original size (10") clutch in these cars. The 1979 to 1985 V-8 Mustangs were equipped with 10" clutches from the factory. We recommend replacing the stock system with the upgraded McLeod 10.5" clutch/pressure plate system. Upgrading to the 10.5" clutch will require McLeod Flywheel part # 463100 or 563100, with the proper counterbalance, in place of the factory flywheel.
what would the proper counterbalance be?
Our engines arent internally balanced.
Just get a flywheel for your model year and it should already be attached to the backing of it.
Just call ahead when you place the order to make sure.
