ok wtf!!
ok wtf!!
ok i go to compare prices of the transgo shift kit on summit which is $119 and free shipping with ebay..... so i start lookin a ebay and the shift kits are completely different than on summit..... so i get on the transgo site and realize that the ebay transgo shift kit is a "reprogramming kit" and the summit one is a "shift kit" cause they say that on the box...... here are the two different kinds:
the summit one:
the ebay one:
what is the difference between he two and which one do i want..... i want to be able to chirp the tires when changin gears and have the more agressive of the two..... can i install the reprogramming kit myself like i would the shift kit??? i need help cause im buyin today....
the summit one:
the ebay one:
RE: ok wtf!!
when in doubt, go to the source
http://www.txchange.com/sk.htm#FORD
I haven't reviewed the info though so find the part numbers you're looking at in Summit and Fleabay and compare for yourself.
RE: ok wtf!!
looks like you want the "reprogrammer" kit
off transgo site: from the "reprogrammer" page
" Firm muscle car shifts; Hold 1st, 2nd, 3rd to any rpm.
Wide open 3-4 shift; Holds 4th at high speed.
Includes Hi-Rev kit. "
then from the shift kit page
" Calibration and Assembly Upgrades. Installs in 10 minutes. Crisp but Smooth Shifts. Corrects/Re-duces/Prevents: 4th band failure; 2nd roller failure; long soft 1-2 and 2-3 shifts; soft lockup; reduces accidental high-pressure parts breakage. Special Hi-tech fwd clutch rings, SOL regulator valve & EPC relief. For firm shifts use AODE-HD2 "
