Quad shock
remove quad shocks to fit bigger tires.
quad shocks were fords answers to a weak 4 link set-up
and cheap rubber bushings
upgrade your control arms and you can take em off.
they push against the axle as it trys to rotate under load
is what they are for.
If you install lakewood traction bars in place of your lower control arms, you need to remove them. As the 2 horizontal shocks will bind, or prevent the traction bars from doing their job.
-P.
-P.
