Overheating problem
Old Jul 23, 2006 | 09:03 PM
Mac 108's Avatar
Mac 108
Default Overheating problem
I have a 90 Ford Mustang with a carbed 306 with a T5.
I got completely swindled on buying it, it repeatedly overheated on the way home and I may be stuck with it.
Anyway, the problem is that the car overheats after a few minutes of driving. It does not overheat at idle, at least it does not overheat as rapidly as when it is driving.
There are no leaks, the coolant reservoir and large aluminum radiator are full, no hoses appear to be collapsing and the fan spins like it is supposed to.
I removed the thermostat and it cooled down significantly, but it still began to overheat after about 15-20 minutes of driving. This was not bumper to bumper traffic either.
Any ideas on what the problem could be?
Old Jul 23, 2006 | 09:06 PM
88stangaruu's Avatar
88stangaruu
Default RE: Overheating problem
maybe the head gaskets are on backwards. Its easy to do. Or maybe its overbored to much.
Old Jul 23, 2006 | 09:09 PM
Mac 108's Avatar
Mac 108
Why would it overheat if it were over bored? Also how would I know if the HGs are on backwards? I am new to V8 engines.
Old Jul 23, 2006 | 09:14 PM
w8less's Avatar
w8less
ur head gasket(s) are blown or in a worse case scarnio ur head(s) are cracked or warped
Old Jul 23, 2006 | 09:34 PM
Mac 108's Avatar
Mac 108
They are blown? I have no smoke or leaks.
Old Jul 23, 2006 | 09:37 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
I would flush the rad..napa make some really good stuff in a blue plastic bottle..also check the clutch on the fan....going to a 3 core rad about 135.00 will help a ton and use a mr. gasket 185 stat
Old Jul 23, 2006 | 10:14 PM
Mac 108's Avatar
Mac 108
The thing is that with the thermostat removed, it idled for about 15 minutes with no change in temperature. There are no leaks or smoke.
Old Jul 23, 2006 | 10:15 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
so is the t-stat opening? im not too technical but from what ive read.. if it dosnt open or meet operating temp it will not cool properly
Old Jul 23, 2006 | 10:19 PM
titanium92's Avatar
titanium92
Are you getting anti-freeze flowing into the overflow tank? What are your other signs that it is overheating? If you are only going by what gauge is reading maybe just your gauge.
Old Jul 23, 2006 | 10:23 PM
lookinforastang
I ♥ Acer
didnt even think of that.. the stock gauge is junk
put a thermo light on ur t-stat to get an accurate reading
