A/C Help Quick!
Old Jul 25, 2006 | 12:06 AM
5.0 MPG's Avatar
5.0 MPG
Default A/C Help Quick!
Okay I am pretty sure I found the source of my leak. The "clutch cycling pressure switch" on top of the accumulator was leaking. I replaced it and no leak BUT there is a small screw inside the switch that controls the clutch on the compressor. When I first put it on the clutch kept engaging on and off every 2 or three seconds so I backed the screw off until it stoped and maybe a little more. My question is how do I adjust this screw to where it needs to be?
Old Jul 25, 2006 | 12:37 AM
white93pony's Avatar
white93pony
Default RE: A/C Help Quick!
you will need to hook some gauges up to it and make sure it is full of freon and nothing is stopped up if not full fill up and adjust it till it stays on such as u did before if it is full then your fine leave it alone
Old Jul 25, 2006 | 12:44 AM
5.0 MPG's Avatar
5.0 MPG
cool, I'll put the guages on it later.
all it does is protects the clutch for excessive wear and tear at WOT and lower outside temps. I was worried I would do some damage by not adjusting it.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
69Volunteer
Sep 30, 2015 10:39 AM
Sep 25, 2015 06:30 PM
