free horse power
RE: free horse power
i think the butt dyno has tendancies to lie to you,,you put money and time into something andyou expect results,,but a perfect example is my friends 95 Probe GT he had an almost bone stock car dyno at 156hp which isn't too bad for the car,, he then spends $5000 building the so called bad *** motor for it,,installs it and swears by how much more powerfull it was than before,,and come dyno day he lays down a pathetic 132hp,,, lota money lota effort and the butt dyno lied , i rest my case
It still takes an intelligent individual to run the dyno, things like engine temp, outside temp, humidity, bar pressure, etc. all needs to be the same for repeatable results. Alot of dyno operators don't take the time to put procedures in place for consistant runs.
regardless of all that don't you think if given $5000 to build a motor you could do better than losing 20hp even with a chimp running the machine, i would put money on the fact that you could.
what i am saying my friend made some bad choices in parts selection thought he had good results until he got to the dyno much like sticking a cutup tin can in your intake and expecting something out of it,,your preception of drivig it is different because you think you will get results
Auto manufaturers spend million, if not billion, of dollars each year paying engineers to develope better ways to increase performance and economy
10-05-2015 06:07 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
