Removing tranny question
Okay so I just removed the 2 Nuts on the Tranny support crossmember. Then it says, remove the retaining bolts..What retaining bolts?Is it the ones i just took the nuts off of?The top is round and im not sure if they just push through or not.If they do they are rusted,I dont wanna hammer at them unless they need to come off.
The cross member is held in place with two bolts that are about 5-6 inches long, they are at either end of the cross member and may need to be drivin out with a punch and hammer. NOTE!! the trans MUST be supported when you remove these bolts.
