Smoke during startup after intake manifold upgrade
I had an Edelbrock Performer intake manifold installed recently. Now, about half the time I start the engine, I get a bunch of white smoke from the exhaust. Is oil leaking into the piston chambers or something?
Thanks.
'94 GT
Fluidyne radiator
Pulleys
24lb injectors and mass air sensor
K&N filter
Edelbrock performer upper/lower intake
Trickflow Twisted wedge heads
Dynomax 2.5" exaust
BBK fuel pressure regulator
suspension lowering kit
BBK upper/lower control arms
King cobra clutch
Pro 5.0 shifter
190 lph fuel pump
Thanks.
'94 GT
Fluidyne radiator
Pulleys
K&N filter
Dynomax 2.5" exaust
King cobra clutch
Pro 5.0 shifter
190 lph fuel pump
RE: Smoke during startup after intake manifold upgrade
yeah leaning over the motor sucks......i agree and check you pcv system also...i forgot to install the lower intake baffle when i did mine blew smoke bad,and it was white.
