another cam question
Old Jul 30, 2006 | 01:31 AM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
Default another cam question
well im nearly ready to start building and ive finalized my selections on parts..except a cam. camshafts evade me for some reason. probably because i get to bored to read all the information about them.
so i'd like to hear you experienced engine builders chime in
my set up will be:
331 stroker
afr185s
holley systemax II
bbk 75mm tb
hooker super comp longtubes
24# injectors
150 shot n2o
so now the 2 cams im looking at are trick flow cams
one is advertised at 275/279 duration and .499/.510 lift
the other 286/294 .542/563
would the second cam be too big for my application? i want this to be a reliable daily driver, but i want it atleast in the 12s. is there anything else i should be looking at when shopping for a cam? i know custom ground cams are better, and will probably buy one ...but thats later on. thanks for the tips
Old Jul 30, 2006 | 02:51 AM
FiveLiterRiceEater
Default RE: another cam question
bumpy. you guys post too damn much! not even an hour and my ****s almost on the second page lol
Old Jul 30, 2006 | 02:56 AM
leadfootdriver's Avatar
leadfootdriver
ORIGINAL: FiveLiterRiceEater
my set up will be:
331 stroker
afr185s
holley systemax II
bbk 75mm tb
24# injectors
150 shot n2o
I'd run the 2nd one. Just make sure you run the rear gear that they specify. You'll be in the 12's no problemo.
w8less's Avatar
w8less
the 2nd cam would be better in my opinion and i would upgrade to 30# becasue of the n2o. have u upgraded ur fuel pump? ur will also have to recalibrate ur MAS becuase of the injectors
Old Jul 30, 2006 | 03:01 AM
FiveLiterRiceEater
i know about the maf recal. and i didnt think about the 30# with the n2o good call. for the gears ill probably be runnin 3.73s or 4.10s. just depends on if i wanna ditch the 3.73s now. thanks
Old Jul 30, 2006 | 03:03 AM
OnyxCobra's Avatar
OnyxCobra
IMO that second cam is gonna be hammering pretty hard for a DD...
Old Jul 30, 2006 | 03:06 AM
w8less's Avatar
w8less
that cam is small compared to mine and it does fine for DD just make sure u get a vacuum canister as well and upgrade ur vavle springs to double springs. also what is the lobe seperation on the 2nd cam?
ORIGINAL: OnyxCobra
Old Jul 30, 2006 | 03:07 AM
OnyxCobra's Avatar
OnyxCobra
well almost any cam could do fine for a daily driver, its just going to be idling pretty choppy, moreso than I would want in my DD for sure
Old Jul 30, 2006 | 03:09 AM
FiveLiterRiceEater
the lobe seperation is 112 degrees.
im not too concerned about the idle, as long as it doesnt die at every light.
Old Jul 30, 2006 | 03:10 AM
w8less's Avatar
w8less
but she has a very nice lope to it hahaha. honestly its not as bad as u might think; the only thing i really regret is taking off my a/c cause its been hot as hell.
