i need a good launch?
Old Jul 31, 2006 | 02:46 AM
blk89lx's Avatar
blk89lx
Default i need a good launch?
ok i want a good launch.. so far i got a custom built 2600 stall converter with cooler installed i have a auburn pro with 4:10's waiting to be put in. im thinking about a good valvebody maybee lentech? i deff need sum radials to complete it. anything else u guys suggest?
Old Jul 31, 2006 | 02:48 AM
OnyxCobra's Avatar
OnyxCobra
Default RE: i need a good launch?
upper/lower control arms and subframe connectors
Old Jul 31, 2006 | 03:36 AM
Stevens91gt's Avatar
Stevens91gt
higher stall and
Old Jul 31, 2006 | 03:52 AM
88stangaruu's Avatar
88stangaruu
Get some Megabite Jrs...worked wonders for my suspension, i had all but given up hope having any traction whats so ever in 1st and 2nd. But now, no spinny anymore.
A set of mickey Thompson slicks helps to by the way. lol
Old Jul 31, 2006 | 04:46 AM
luckythirteen13's Avatar
luckythirteen13
ORIGINAL: 88stangaruu
what hole did you use on the rear mount for the MB jr's, the upper or lower? just curious
i too would go with a higher stall. subframes, upper and lower control arms, adjustable shocks in rear, adjustable struts in front and a good set of drag springs at all 4 corners
Old Jul 31, 2006 | 05:46 AM
88stangaruu
the highest grip one. And just incase your wondering, no my car doesnt sit any lower in the rear.
Old Jul 31, 2006 | 06:12 AM
primetime5.0's Avatar
primetime5.0
battery relocation
Old Jul 31, 2006 | 02:49 PM
iceman89gt's Avatar
iceman89gt
nitto drag radials if your gonna go radial, good set of after market upper and lower control arms, drive shaft loop, subframe connectors and battleboxes and i could keep going, but thats the basics also be sure the upper control arms have enough reinforcement in the floor pans so your tunnel doesnt crack like mine did.
Old Jul 31, 2006 | 02:58 PM
88stangaruu
If you want to be able to launch the **** out of your car and not have grief about it your going to need something like this....
i mean to really get into it, some arnt 'Mandatory' like the K member, but its nice to have.
-Lakewood 90/10 shocks up front and 50/50 in the rear.
-4cylinder springs up front, stock V-8 springs in the rear with a air bag in the passenger side rear.
-Mega bite's or mega bite jr's set on the highest traction settings.
-Any upper control arms, adjustable preferred.
-Maximum Motorsports Subframe connectors
-Maximum Motorsports tubular K or a comparable tubular k to lighten front end.
-Battery to trunk conversion
-Mickey Thompson E/T slicks
-Torque box re-enforcements (Launching will rip them after a while if they arnt re-enforced)
And once that front end rises at the track, your going to have to speed shift your *** off to make sure it doesnt drop any and un-load the rear suspension. But that should get you to about where you want to be. A good set of slicks and control arms should get you on your way, but the rest is going to make a real difference.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
ctgreddy
Sep 20, 2015 08:35 PM
Dragonus18
Sep 9, 2015 01:21 AM
Sparks_88
Sep 8, 2015 01:06 PM
vintageaion
Sep 8, 2015 10:45 AM
