Depends on the year of your car...In 1990 they changed the drive gear so you might have to change that too...I just did mine this weekend.
Anyway you need a 21 tooth driven gear (red) and a 7 tooth drive gear (yellow)
im pretty sure you need to change something else if you're gonna run a 7 tooth gear, if its stock you need an 8 tooth gear, its a white 23 tooth. However it wont fully correct your speedo, it will be very close ( the white 23 tooth is for 3.55s, none are made for 3.73s in 8 tooth drive)
Yeah you're right about the 8 tooth. That's why you have to change to a 7. Then he can use a 21 tooth driven gear and it will be correct for 3.73's. I had my gears done last week and then put a clutch in this past weekend, so while I had the trans out I changed the drive gear to a 7 tooth. My car is a 91 so it had an 8 tooth drive gear.
This only has to be done if he has a 1990-95. The 83-89 came whith the 7 tooth drive gear so he just needs the 21 driven gear.
