Posi no longer works
RE: Posi no longer works
ORIGINAL: Stevens91gt
haha hell ya its humid as hell out there
jeeesh..its nasty
but other than that..seems like a nice place
jeeesh..its nasty
yeah we actuallty have a pretty clean air where im at u can tell theres some type of plant that grows on the oaks around here wouldnt grow if the air was bad? but now? but in other areas of cleaniness were on a superfund site here in brunswick[&:] not good i think were 2 in the nation a company lots millions of pound of mercury over the years
if im thinking correctly you could even rebuild it with the carrier still installed in the car, i would rather pull it and have new bearings pressed on as im sure they need it but i think it can be done. you need to pull the z clip out, pull the c clips holding the axle shafts in place pull them out enough that the the splines are out of the carrier pull the plates and the friction disks out and replace them. make sure you soak the new friction plates in gear oil for at least 20 min before installing them, if you can soak them for a couple of hours its better. they dont pop as much when you first start driving.
