help!!!
Old Jun 3, 2004 | 06:10 PM
luckythirteen13's Avatar
luckythirteen13
Default help!!!
im trying to install my new manifold and the lower half wont come out. i have all the bolts out but it still wont budge. what should i do? do i force it? or is there a trick?
Old Jun 3, 2004 | 06:15 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: help!!!
wedge a screwdriver or paint scraper (carefully!) at the gap where the manifold and head or block meets to get it started. Once you get it in and break the seal the intake will just pop right off. You just want to be careful not to scar the heads/block/or intake up by scratching any of the parts badly when you do it.
Old Jun 3, 2004 | 09:52 PM
86HOGT's Avatar
86HOGT
Default RE: help!!!
Take a pry bar into the thermostat portion of the manifold. I you haven't taken it off already, take the actual thermostat housing (the part that holds the thermostat) off first so you don't break it.
Old Jun 4, 2004 | 03:25 PM
luckythirteen13
Default RE: help!!!
ok, after about 12 hours of work and 100 trips to the store for random stuff, i got the lower and uppper intake in. my question now is this: as long as all the vacuum lines are plugged back into the upper half, ill be fine right? i mean, the new upper is a little different then the old but i did manage to but all the vacuum lines back in. i had to take a couple of the small ones, hook then to a T fitting and then into the upper intake cause it had one less hole then the old. after i get the TP sensor set, it should fire right up....right? i hope
Old Jun 4, 2004 | 04:53 PM
WNDSOR's Avatar
WNDSOR
Default RE: help!!!
if you got your timing set right, yes it will, or did you take the dist out?
