hmm...electrical problem?
RE: hmm...electrical problem?
ORIGINAL: BascoSauce
ha well i understood half of it....and the other half....uhhhh[>:]?
can someone, or even 5.0MPG put that into terms a noobie would understand, thanks for the post, appreciate it, but if you could help me understand it that'd be even better!
THANKS
ORIGINAL: 5.0 MPG
go to AZ or Advanced and get a can of electrical cleaner and some dielectric grease.
Your key getting stuck in the ignition is more than likely your tumbler, key lock, or ignition switch. take the column covers off and do some inspecting, cleaning and greasing.
the first electrical issue is more than likely the switch. moisture shouldnt affect them. you will need to take the armrests off your doors and unplug the connectors clean them real good then grease them with the dielectric grease. This grease prevents corrosion and moisture from coming in contact with those pins.
the second issue sounds like your instrument lead coming off your solenoid. take the positive side apart being sure to first label the order the wires are in first. clean and grease them.
badda bing!
badda bing!
THANKS
ORIGINAL: 88stangaruu
Auto Zone or Advanced Auto.
Hey...what about me? My key's still f*cked up?
Jesus...no respect for me at all [>:]
lol
lol
and dawgggggggg, calm down, let the man have a minute, and its already been one, and you have a response!
wooooooooohoooooooooooooooooooooo
THANKS 5.0MPG
stangin1996gt
09-21-2015 11:01 AM
