Ignition control module question
Old Aug 3, 2006 | 09:07 PM
bouchermb's Avatar
bouchermb
Default Ignition control module question
I just bought an MSD 6AL and just saw it needs to be used with a module kit that includes 5 modules per kit that has 200 RPM increments.
My question is do I need the kit and if so, which one should I get?
3,000-3,800 RPM kit
4.000-4,800 RPM kit
5,000-5,800 RPM kit
6,000-6,800 RPM kit
Thanks
Old Aug 3, 2006 | 09:36 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Ignition control module question
It's for the rev limiter and yes you need it. I have the 6K one in mine.
Old Aug 3, 2006 | 09:51 PM
bouchermb's Avatar
bouchermb
I'll buy one, but still don't know what one I should get.
I don't race the car much, if at all, so I'd want one that's good for my mods, but not a higher range than I'd need.
Does that help at all?
I have a 5 psi SC, 73 MM MAF, 70 TB, pulleys, TF Street upper/lower intake, BBK 1 5/8 equal length headers, 355 gears, full three inch exhaust with Borla mufflers, AFPR 190 lph FP, Fluidyne radiator and a bunch of other stuff that I don't think matters.
Old Aug 3, 2006 | 09:52 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
The mds box didn't come w/ any. Mine did.
Old Aug 3, 2006 | 09:53 PM
bouchermb's Avatar
bouchermb
Any recommendation on what range would be good?
If not, I can call Summit and see what they think.
Old Aug 3, 2006 | 09:55 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
It depends on what mods you have. Even though mine has a blower, the rest is basicaly stock so 6K is where I want to be.
Old Aug 3, 2006 | 09:59 PM
bouchermb's Avatar
bouchermb
I just found out from Summit the ignition box comes with the modules.
I guess I'll just need to decide which one to use.
Old Aug 3, 2006 | 10:07 PM
bouchermb's Avatar
bouchermb
I think I'll use the 5,000 to 5,800 RPM module, unless someone thinks I should use a different one.
04stangman
Sep 17, 2015 01:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 2, 2015 04:12 PM
