what is first to give?
RE: what is first to give?
a rod bolt would break at about 490-500hp, if it didnt go first, the rings i would imagine or if you had detonation even once or twice under load with pretty high boost, a piston may crack or the rings just be destroyed by it. definatly the rod bearings would be shot all to hell.
dont spend to much money...unless you buy a better block.
Id go with a stock crank and some H-beam rods...that's all you need.
Oh and ARP bolt/stud everything.
The mains should be studded as well as the heads.
ARP Wave loc bolts should be used in the rods as well.
Matt's 95 Stang
10-05-2015 07:16 AM
