Bucking still!!!!!!!!
Old Aug 8, 2006 | 11:31 PM
jzgt's Avatar
jzgt
Default RE: Bucking still!!!!!!!!
Yeah - it's the first runner on the lower intake of the driver's side.
Why did they remove the distributor? If you just changed wires, they shouldn't have pulled the dist. out. The only reason for pulling the dist. to move it is if there isn't enough adjustment (module hitting the thermostat housing) for you to get the timing right. Did they say your distributor was off 'a tooth' or did they change the plug wires?
I'd check your timing & check your plug wires to make sure they're going to the right places (let me know if you need the order).
Did you just put the motor together?
- Jeff
mungodrums
Oct 7, 2015 04:01 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
jstrothe
Sep 24, 2015 12:17 PM
SteelerNation82
Sep 16, 2015 07:11 AM
